Newbie- Opening Received model warnings
Berrys_Cooling_Drafter
Hi all, starting my path in revit I need some help, please explain the most you can so I can learn from these walls I hit when using this great program.
I am a Mechanical Drafter. So I received a file from an architect. Wanting to model in the ductwork, when I opened the file, I got all these warnings-see attached. Can you please explain what's going on,  what does each of them mean, and why they are coming up. And what needs to be done so I can open this file and that this shouldn't happen again with other projects in the future.
Please don't give me a few words answer, so I can get the most out of this issue I just got into. As we all know, every such situation is an opportunity to learn.
Well, if a "few words" is not what you want, then I would suggest drilling down in this Link.  "LOTS" of word here.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
RobDraw
Have you tried searching the internet for those errors? Lots of words out there.
Rob
I much appreciate your time and efforts to help me out with my issue. As soon as I have a chance, I am going to drill down into this link. But do you have anything that you can tell me in a "Few words" what's happening and what I need to do?
mariah.ferranti
Hello @Berrys_Cooling_Drafter ,
It looks like you're running into the following things:
Error 1: The central model <Filename and path> cannot be found, perhaps due to a lost network connection.
  • Your model has become orphaned form it's central model.
  • Most likely someone sent you their local file.
  • You want to select 'Detach from central' when opening the file (Shows up as a check-box at the bottom of the open window). Then save-as, and you won't likely see this again.
  • If you want to get rid of worksharing completely, do the following when opening the model:  Disable Worksharing | Revit Products 2019 | Autodesk Knowledge Network
Error 2: Opening worksets
Error 3: Some families have become unusable. Reload the families, or delete them from the model.
  • Some families are corrupt. You need to either delete them, or if you do you have good copy, you can try and reload.
  • If this is a file from a client or 3rd party, you likely don't have a good copy of the families for reloading. You should let them know, in case important information would be deleted.
Error 4: Data in file <name and path> is corrupt and needs to be manually recovered.
Hope that helps! Feel free to press 'Accept solution' if this answers your question, or reply back if you need more assistance.
  The issue was that it was modeled in 2017 and I was opening it in 2019. The update for some reason was causing the crash. I realized this after downloading a 2017 trail, and it opened the file.
Thank you for your time to answer me with such detail I greatly appreciate it. I will look into the links you posted as soon as I have a chance.
