texture mapping
texture mapping
arkitek2ss
Message 1 of 8
texture mapping
arkitek2ss
any website or anything that can show how-to add tile inside of tile and how they work within Texture Editor?
Replies (7)
Message 2 of 8
Tile inside of tile?  Are you talking about a Rendering Image?
Message 3 of 8
arkitek2ss
trying to get the look of plank flooring as shown (GD using hidden line)
but I get this.
trying to understand how to place a sub tile appearance within the main tile.
Is there somekind of guide or How-To
Message 4 of 8
cbcarch
Your texture map ( .jpeg or .png, etc.) does not look correct.
Try finding a better image of the wood flooring / pattern that matches the hatch pattern ( running bond ).
Also, it is best to use a "seamless" texture to avoid "tiling" or "repeating" of the pattern.
This can be done in photoshop or other image editing apps.
https://medialoot.com/blog/how-to-make-a-seamless-texture-in-photoshop-redux/
https://www.youtube.com/watch?v=FR3Z0zr1RaY
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 8
Besides using an image for the wood pattern, you can also use Revit's procedural tile and custom it to your liking and to match the surface pattern.
Message 6 of 8
arkitek2ss
actually, the texture map is nothing.  just a color for a place holder until i can get the tiling done correctly.
i was trying to use a single plank and have it repeat and offset but I guess revit can't do that.
is there somewhere that does the How-to on how to manipulate textures?
Message 7 of 8
arkitek2ss
ToanDN,
didn't see your post until after my last post.  is there a how-to or something to do that?
Message 8 of 8
@arkitek2ss wrote:
ToanDN,
I am not sure.  You can certainly google it.
But there is only a hand full of options (okay maybe two hand full) that you can experiment to get the job done.  In the example I changed the number per column and row to get the offset effect.
