Text in txt file not recognized
mairh_tsek
mairh_tsek
Hello all,
I created a .txt file with the coordinates (XYZ) and at the beginning I add also the name of the element. For example A1,555,434,2.
When I import the txt in dynamo the first value with the name it isn't recognized.
Can I do something in order to solve this problem?
Thank you in advance.
Has to be a CSV file in order for it to be viewed using that node. "Save as" or re-input your txt file into a csv, then import it the same way into dynamo. You may need to identify the first column as a string in order for it to register in your parameter inputs as well.
mairh_tsek
If you check the image above I used the 'importFromCSV' in order to import the txt file. And I identified the first column but I receive the warning. Is it because instead of number I have text in the first column?
Thanks!
Get rid of the first column....it recognizes the coordinates not the label.
I am aware, but you cant use that node with a .txt file.
That node only imports .csv files.
Use the filesystem.readtext node. Then you may need to do some list management to split values from their commas into lists.
mairh_tsek
Thank you , I used the String.split node .
