Every time I select a text box field, a glitch appears blurring text fields with colors shades and replacing text from the project browser tab. It does not affect any work, it's just the visuals that are affected, and resolved by clicking elsewhere in the schedule. Any feedback would be appreciated.
Assuming that it's not because you have some conditional formatting in the settings of the schedule, something else that could be is that you have two monitors with different scale values.
Could you help me understand what a monitor scale value is, and how to modify it?
I'm using two monitors that are identical, they shouldn't have different configurations or settings.
TIA
Try updating your graphic card driver and see if that helps.
TIA
When you right-click on the desktop screen > Display settings , there is a setting called "Scale and layout".
