Symbolic lines from family are not showing as intended on model
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
David125
298 Aufrufe, 4 Antworten
Symbolic lines from family are not showing as intended on model, when I create a new project the symbolic lines show up fine. Is it some thing in my visibliy settings?
I've posted the problem project with the family in place.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: David125
Your phase filter is Show Previous + New, and you have Graphic Overrides for New.  Remove Overrides for New or change the View to Show Complete.
Nachricht 3 von 5
syman2000
Weird...if I load the family into the new project, it looks like this.
I check your file, it has to do with the phasing filter
Nachricht 4 von 5
David125
I unintendadly accepted the last post as a solution to my problem, it did not work.
I did solve my problem. There has never been an issue with phasing and phase overrides, till now. As an act of desperation I removed all overrides on the phasing and applied them. The symbolic lines show fine. I then reapplied the phase overrides and applied. My symbolic lines still show up as intended, problem solved.
Nachricht 5 von 5
Sorry but if you read my post carefully you would have solved the problem more quickly.  I can guarantee that your correct phase overrides has New = By Category, and the incorrect phase overrides has New = Overridden.
In an essence, New should never be set to Overridden in any Phase Graphic Overrides if you want to see elements with their unmodified presentation.
