Text Editor
Text Editor
Text Editor
Add additional/advanced text editing controls such as a text box with a ruler and multiple tabulating controls.
Also, the ability to control/scale text box sizes for imported drawings would be fantastic. Currently, if a cad file using non Arial font is imported, text will jumble/overlap and look sloppy because the font characters have different widths. Converting all text to Arial or Arial Narrow should not be the acceptable solution.
lionel.kai
A ruler might be nice (and I would think essential for having custom tabs). related:
http://forums.autodesk.com/t5/revit-ideas/roman-numeral-list-type-hanging-indent-and-custom-tab-stop...
but how would you want to control the text box sizes - as a global scale factor applied to the import? like all text using Simlex with 0.75 width gets 1.2 times wider when converted to Arial at 0.85 width (for example)? It would be nice of Revit was smart enough (at least for single-line or two- & maybe three-line text) to figure out what the width needs to be to keep the same line wrapping. Obviously for larger blocks of text there's no way to guarantee that everything wraps the same when changing fonts, but it would be nice if there was a "TRY to maintain line wrapping for Text" option during the import?
Lionel J. Camara
BIM Manager at KAI Hawaii, Inc. - Structural and Forensic Engineers
Autodesk Certified Professional
Discussion_Admin
Notice
This post was moved from an Idea station due to it having more than one Idea per submission for the team to consider as per the guidelines.
The original author has been notified of the move with a request to post the ideas individually.
Anyone who voted for this Idea is encouraged to return to the Idea board and vote on the new ides listed individually.
Thanks in advance for you understanding
Discussion_Admin
