TEMPORARY DIMENSION
TEMPORARY DIMENSION
TEMPORARY DIMENSION
When I click the wall it doesn't activate the temporary dimensions for me to adjust the dimension . I have checked the constraints by reavealing constraints and that is not the cause of the issue. The file is attached for perusal .
When you select a wall, have you check "activate dimmensions" in the left upper corner?
bimscape
Is the dimension to the left of the wall (near the top of the stairwell) one that was a temp dim and you made it permanent? Because it is connected to the wall in question.
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Activate Dimensions. (Options Bar)
Note: At a certain point, Revit will stop showing temporary dimensions automatically to conserve resources.
....this explains why:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
I think it depends on the selection.  Example below showing two families in the same file, one needs to activate dimension and the other does not.  I still don't know why.
yes
yes, It worked for the time being but it doenst always work like that.
