Void through a topography
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
I wonder if it's somehow possible to create a void through a topography? (beneath the surface)
We need to create a hole for a tunnel.
Also, I noticed that Revit creates the depth when you cut it with a section box. Is it possible to create real surfaces in another way or how does it all work?
When I export the same topography to an IFC I get different results depending on the section box.
cbcarch
Try:
1. Using a Building Pad
2. Use Dynamo--a bit more complicated, but it works. See this: https://www.linkedin.com/pulse/underground-modelling-within-revit-gary-fellows
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Marcus.Isacsson
@cbcarch wrote:
Try:
Thanks for your answers.
1. How can you create a tunnel with the building pad tool?
2. Thanks for sharing this, looks neat. Couldn't find the Dynamo script though.
cbcarch
It's a combination of toposurface and a floor--
The floor can be made to match the shape of the toposurface.
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/revit-for-architects/ab3340#ch...
Cliff B. Collins
Sahay_R
Look at this thread -
https://forums.autodesk.com/t5/revit-architecture-forum/topography-and-tunnels/td-p/4312041
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
