Technical report (Word file)
XXalessio.amodioXX
XXalessio.amodioXX
hi all.
I have created a sheet list in revit.
I want to import in one on those a technical report and analytocal report written in word.
How can I do?
Export the Sheet list that you have created (file/Export/Report) and open it with Excel.  Then select the cells and import them into Word as a table.
You can open the export directly from Word, but it will be all over the place.
XXalessio.amodioXX
Hi thanks for the answear is how to IMPORT word file in revit
You can't import a Word document into Revit.  But you can copy the text in the document and paste into Revit on the sheet that shows your schedule.
