Tapered Wall with deleted Hosted elements (phasing) not working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
I'm concerned that using phasing to represent deleted elements hosted on a tapered wall, is not possible to do.
A simple exercise we can do it's just create a wall (activating the variable parameter in a wall layer), change its corss section to tapered, activate the cross section instance parameter and than selecting the angle for both sides; after that we can insert a window/door on it; then, if we try to demolish the window, revit will send you a waring saying "Cannot set angles on a tapered wall which has angles controlled by the type." But, as we saw, we defined the angles in the instance parameters (not by the type, as the warning says).
This could be because of the way a tappered wall angles are applied to a wall, once it cannot generate a second wall in the window/door insert with the host wall definitions. But maybe someone can just confirm to me that there's no way to use a tapered wall with deleted hosted elements or some enlightenment on how to do it.
Thank you in advance!
