- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good morning,
Team members have been reporting issues tagging stacked walls. When a stacked wall is tagged, it gives a blank tag that allows you to tag the entire stacked wall assembly, instead of the component parts separately, which would be more informative to the contractor. The workaround devised has been to duplicate the component walls and then tag separately.
Looking at old threads tells me that this has been a long standing concern. Has anything changed? Would it be possible to tag parts of a stacked wall separately without having to resort to cumbersome workarounds - which defeats the purpose of stacked walls entirely?
Rina
Edit - see this when I ad tags in section (yes, I know, this is a funky looking wall, I just needed some walls that look entirely different)
In plan, however, Revit only shows the bottom wall.
Is there any way to see all the tags in plan as well?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
