I am not sure if this is possible but my goal is to be able to create an active room tag in a host model for a nested model room inside of a link. Using Revit 2022 - The set up for the project is small units (A model) linked into a building models (B model) and building models linked into a complex (C model). All sheets for construction have been requested to be created in 'C model'. I can create active room tags in the 'C model' through the Revit link display settings for the linked 'B model', or if I link 'A model' into C directly. I can also get the nested room tags from a specific view from A -> B -> C showing (all set up as attachment links), but can't tag the nested rooms the way I can the direct link rooms, although I can view the tags *and rooms* from 'A model' showing in the 'B model' linked view. I've tried the "by linked view" and "custom" options and can't get the the function to pull through the nesting. Is there a way to keep the link structure A-> B-> C and tag the nested rooms from A in the C model? Or will I have to settle for linking all the 'A model's into C or having tags that I have to adjust in another model every time there is a conflict with other annotations in C?
Below is the best setting I have found so far
