TAG wall sweeps
TAG wall sweeps
Message 1 of 12
TAG wall sweeps
How do I TAG a wall sweep in Section?
I know I need to use the TAG material... but is not working in section.
Any thoughts?
Replies (11)
Message 2 of 12
Create Parts and tag it, maybe?
Message 3 of 12
I can tag a sweep with a Material Tag in section view. What's happening when you try?
Message 4 of 12
Nothing... I cant select the sweep...
It is note getting the blue line....
Message 5 of 12
Message 6 of 12
@Anonymous: ...or, it's pinned and you have restricted selecting pinned objects (bottom-right).
Message 7 of 12
No problems here either, both in-wall and in-place sweeps.
Message 8 of 12
I am wondering if it is because I am tagging a linked model...
Could this be the problem?
Message 9 of 12
Message 10 of 12
No problem tagging wall sweeps in a link either, and I even set links to not selectable.  Can you use the material tag on anything else in the section?
Message 11 of 12
It is working now. The wall sweep is a very thin profile and I need to click on a very specific point to get the Tag.
Tks everyone for the help
Message 12 of 12
A.elshafey
 I believe that wall sweep tag feature is available on Revit 2023
