Tag "Label" Text Boxes | Adjustable Sizes (in the Project File)?
rhBDHX4
rhBDHX4
It seems wild that in 2023, as far as I can tell, there is still no way to have any Labels in any Tag type have adjustable label-text sizes within the project file.
I realize I can (and have) create sub-types of Labels with visibility parameters to be able to flip between left and right justified Label-text, and to have short, medium, and long Label-text field sizes, but this is a very inelegant solution.
Label text fields should just have the ability to at the least adjust the length of the label in the Project file dynamically with text-wrapping (just like Text in the Project file)...this sure seems like a useful / simple request that has been requested countless times (when I do an online search about this topic).  It would be even better if there was a way (again, just like Text in the Project file) to be able to choose the Label-text justification.
Short of some simple changes to Revit, does anyone have a solution, even if complicated?  Would love to make this less cumbersome for my team--having to toggle between six different sub-types of any given tag, to make it fit on screen, is not an efficient solution....
Alfredo_Medina
Make different types of tags in the family editor. In the project, select the type that works better for each case.
rhBDHX4
This is what I am doing.  It is inefficient at best.  Being able to adjust the size / justification of the Label text on a per-instance basis (just like the Text tool in Revit) would be infinitely more useful/ efficient.
Mike.FORM
john_olav_kopperud
Can Autodesk PLEASE add the ability to adjust Tag label width by an instance/type parameter?
ianloruel-ariasDBHG6
How can you add types for tags? I have tried adding instance parameters but I can't seem to get it to work.
