Systems Analysis
Systems Analysis
20079741
Systems Analysis
20079741
Is there a way of downloading system analysis workflows if they are not present within the file options tab in Revit? Im looking to run an energy simulation but i require the workflows to be installed. For some the workflows arent present on my Revit and there's no default option either.
karistaJBGCS
If you have already done all updates to your Revit software, you may need to do a clean uninstall and reinstall of Revit itself. This process would usually fix any corruption within the software as it's not normal for tabs to be missing in Revit.
Hi there so the tools are now visible on interface but yes the issues with the system analysis are still there. I'm now giving an error message that says "your folder does not contain any workflows", when I select the systems analysis tool
karistaJBGCS
Hi
You will be able to access the workflows via this path for your Revit version
C:\Program Files\NREL\OpenStudio CLI For Revit 2021\workflows\...
When i search for this path on my folder it reads as invalid
