Redundant pattern element exits outside cut divided surface
5 REPLIES 5
heichan88
312 Views, 5 Replies
Hello
I made a normal a cut divided surface and apply pattern, then some redundancy pattern element exits outside the surface area. they are inside a same in-place model, not by family.
Please help how to solve.
5 REPLIES 5
heichan88
in reply to: heichan88
Please see attached rvt, these redundant pattern element should not apprear which are outside the divided surface, quite weird. Please advice Thanks
Change the pattern based curtain panel family to NOT Shared then use a mass to cut it off in the project environment.
heichan88
in reply to: ToanDN
Hello @ToanDN
“a mass to cut it off in the project environment.”
--- you mean this mass to be another in-place mass?  hope it can be cut multiply, OK I try tomorrow
@heichan88 wrote:
Hello @ToanDN
Yes.  I just placed the OOTB box mass and rotate it 45 deg.
heichan88
in reply to: ToanDN
hello @ToanDN
excellent, by change to "non-shared" and done, but I keep 2 in-place model (for both cut mass and pattern), it also works and more simplified and organized.
Many Thanks
