Hello
I made a normal a cut divided surface and apply pattern, then some redundancy pattern element exits outside the surface area. they are inside a same in-place model, not by family.
Please help how to solve.
Solved by ToanDN. Go to Solution.
Please see attached rvt, these redundant pattern element should not apprear which are outside the divided surface, quite weird. Please advice Thanks
Change the pattern based curtain panel family to NOT Shared then use a mass to cut it off in the project environment.
@heichan88 wrote:
Hello @ToanDN
“a mass to cut it off in the project environment.”
--- you mean this mass to be another in-place mass? hope it can be cut multiply, OK I try tomorrow
Yes. I just placed the OOTB box mass and rotate it 45 deg.
