Sweep molding at curved wall
9 REPLIES 9
Message 1 of 10
revitz7F85E
755 Views, 9 Replies
hello
i am trying to make a sweep molding (model in place) at  curved wall it doesn't let me choose the curved wall face to start drawing the sketch path , i cant set a work plane for the curved wall so i can draw at it
9 REPLIES 9
Message 2 of 10
in reply to: revitz7F85E
Choose Pick Path, not Sketch Path to pick the sweep path. You can also use Wall Sweep tool.
Message 3 of 10
revitz7F85E
well i want to draw at specific part of the wall not the whole wall if i used the method u mentioned i will take the 4 sides for the face of the wall but i want to do something looks like this
Message 4 of 10
revitz7F85E
in reply to: ToanDN
Message 5 of 10
I see. Create window or vertical opening to temporarily cut the wall, then create sweep using pick path from the edges of the opening. Delete the opening or move it to a future phase when done.
Message 6 of 10
revitz7F85E
in reply to: ToanDN
i did already used this strategy but i was looking for a method to apply it for complex shapes like making an opening for example like this opening at the curved wall like setting a workplan at the curved wall and start drawing my lines at for example
Message 7 of 10
You can use the opening or void method to create the edges for the sweep path for complex shapes.  It still is the easiest way.
Message 8 of 10
revitz7F85E
in reply to: ToanDN
wow that's impressive may you tell me how u did that thank you
Message 9 of 10
See screencast.
Message 10 of 10
revitz7F85E
in reply to: ToanDN
Thank you so much
