SWEEP - elements created not visible in section view
Hi
I am trying to draw a sweep in section view. When I try to draw it gives the following error message: None of the created elements are visible in Section: Section 2 View. You may want to check the active view, its Parameters, and Visibility settings.
I have tried going to the Visibility/Graphics override for the Section view, and under the Model categories tab I made sure "lines" checkbox is checked.
Any suggestions please?
are you sketching on a workplane that is visible in the view?
So a sweep has been made?
Can you see where it is in 3d?
chrisplyler
So it got created. Go into a 3D view and find out where it went. It is probable that you didn't set your work plane when you were sketching to something that is within the extents of the view.
