After updating Revit to 2020.2 (update from 3 days ago today), I opened a project I've been working on to find the arrows from the Project Base Point and Survey Point to be appearing in all views of the model. Their location is way off the sheet which makes it fine for printing sets right now, but I'm wondering if anyone else has experienced this. And if you've found a way to turn them off or hide them.
I have two showing up. One from the main project and another from a project linked into the main one. When I hide/delete the link, that one disappears, as it should.
As you can see there are additonal arrows that appear when one of the points is selected (as seen in the image with the linked model selected), but the problem is another set of arrows which I can not select in any way.
These arrows are appearing in all views, floor plans, 3D, sections, on and off sheets, with and without templates. You name it. Seems like a visual bug.
One from a link, one in main model
Points Disabled
Points Enabled
