Hello community,
I can't seem to find the properties and project browser window anymore!
I check the user interface and they are checked on but just dont show up...
Any suggestions?
I restarted the program and even my laptop in general.
Are they on the other monitor? In other words, did you have a multi-monitor setup going on at one time?
try to untick use hardware accelerations from options, install latest updates from autodesk, updates your graphics card driver to the latest and see if helps. thanks
or try to adjust your window display setting and see if helps. thanks
