Surface lines from an IFC
3 REPLIES 3
ThijsLugt
804 Views, 3 Replies
We have a project where we are bound to use Revit 2019, one of our partners unfortunately started in revit 2020.
They have made an IFC of there model so we can still load it in our Revit model.
When we load this model it comes with al kinds of surface lines (see attachment)
is there any way (maybe in partners export options of our inport) to get rid of these?
Or maybe other ways to get that model in our revit.
Thanks in advance.
Labels (5)
3 REPLIES 3
amarkonathala
in reply to: ThijsLugt
Hi @ThijsLugt ,
If I understand you correctly, the linework tool set to <invisible> will do it.
ThijsLugt
in reply to: amarkonathala
Thx for the reply, but as there are hunderds of those lines i was hoping for other methods.
The lines shouldn't even be there, as the surface is even/flat at those places...
amarkonathala
Currently it is only possible to overwrite the linework display on an individual line basis which makes it really slow to do it for dozens of lines. Please make it possible to select multiple lines for the override.
Check Below Link for reference
https://forums.autodesk.com/t5/revit-ideas/linework-override-for-multiple-lines-at-the-same-time/idi...
