surface by two rail and one profile
paolo.campana
paolo.campana
Hi all,
I have some trouble to define this kind of element,
It's a simple surface generated by two rail and a profile.
It's pretty simple by other software but revit seems not agree too much with this,
Which is the best way to define this kinf of surface in revit?
RDAOU
@paolo.campana
If you insist on working in Massing Environment, you will need more than those 2 paths (circles) and that Profile (arc)...otherwise, you would be better of if you use a simple Revolve
Example on massing
constantin.stroescu
having your elements as base I'd use the two circles from the bottom and from the top to create a Form and then to obtain the curve (generative) by creating an intermediate Profile , as shown in my screencast:
play with Masses | Search | Autodesk Knowledge Network
in fact what matters is to obtain the desired  result not the used method....
Constantin Stroescu
Alfredo_Medina
@paolo.campana  It does not work that way in Revit. You need two things: a) one reference line that works as the center of revolution, and b) the arc that you want. Then select elements a & b, and do Create Form.
syman2000
Adaptive environment is different from the traditional loft with 2 profile tool. In this case you can try revolve as mentioned above or you define another circle in the middle and select all three profile to create your shape.
RDAOU
A simple revolve using an arc and an axis of revolution is also possible in massing environment...the question is though what is the ops intent...just a revolved profile or a little bit more than that
