GRID BUBBLE NOT SHOWING
Whenever I make a grid line, the grid bubble does not appear. I don't know what the problem is. I have checked the boxes. I went to the properties section but in the symbol tab it shows "none". In sample files which are already present in revit, it shows 2 options "none" & "M_Grid Head - Circle".
Kindly help me with this as early as possible.
RDAOU
@Anonymous
Did you consider loading the Annotation/Symbol family for the Grid Head/Bubble?
Those are usually preloaded in the project templates...if you are not using a project template then you will need to load them manually.
Use Transfer Project Standards to transfer content from that Sample Project into your Project.
Figured out the problem. Libraries and families were missing. I downloaded it from the Autodesk website for Revit 2017.
