Sudden occurrence of Multiple ACC/B360 Users Getting "Sharing Violations" and ""Local File is not compatible with the central model" errors
josephsWYW3U
josephsWYW3U
Is anyone else encountering this? It just popped up over the past 48 hours across multiple teams. I've checked Autodesk for the error. There are two pages on it. One is a conflict with Trend Micro Antivirus, but we don't use that. The other is more generic. We cleared temp files but no dice, we entirely disabled anti virus and again, no dice (did this after we got an incompatible error, did not get to try this with the sharing violation as users blew past it).
  1. Version: Revit 2023 (Checking versions to make sure everyone is on the correct version. A few have been old and I've updated them, but that doesn't seem to be the conflict. Users on the same older 2023 versions are getting the issue)
  2. All projects ACC/B360 (no local)
  3. Workers home and Remote
  4. Cleared Temp Files - Did not help
abelliveau
I've been getting this for two weeks now. Is yours still doing the same?
josephsWYW3U
Yep, I think we got it addressed.
The journal noted Revit couldn’t access some temp files. (I can’t remember the exactly type, check your journal for the culprit). We found out that windows pushed out an updated the week prior that affected reading .xlm files and a few other potential culprits.
That in combination with our security software was causing the issue. We worked with our vendor to tweak some settings and haven’t seen the error since. I’d start with getting a journal, figuring out what Revit is having trouble accessing, and then working with IT to see if it’s a permissions issue.
abelliveau
Yeah, I've gone into the journal files and it's something that ends with "Revit893d8d15-4d3f-4d31-b861-4af338d36dc5.project.xml.zip." Still working with our IT to figure it out.
