Subprojects vs copy monitor linked files
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Melden
Hi, I have an Architectural file, a structural, an electrical and a plumbing file, each one created separately and linked with copy/monitor (link file) and have synchronized their grids and levels with my architectural file. Until there, everything is fine. If there is a change in one file, when I load another one it it gives a warning to update.
The problem is that when I created a central file and linked all the files into my central, I can see them all together, no
The problem is that when I created a central file and linked all the files into my central, I can see them all together, no problem, but how do I integrate this with my subprojects created (Architectural, Electrical, Plumbing and Structure). How do they interact with each other. I understand that with my subprojects I have a user assigned for each one, but isn't this the same with the owner of each file in the copy/ monitor? There are no videos that show how to finish the process, what happens after I create the central with both topic (copy/monitor and subprojects).
How do I work with subprojects and linked files with copy/ monitor at the same time. Also there is an option with link to current project file in copy/monitor and don't know what is its use. Little confusing all these. Can you help me please. Urgent.
