Structure pattern transparent in sections.
ccarniel8
Observer Observer
ccarniel8
Observer
Observer
 The structure I modeled is not showing over the walls or floors. Even if I manually try to add a pattern it still looks like this:
Does anyone knows how to solve this? It´s not the first time I have a problem with this situation
 Join geometry structural members with architectural walls/floors and switch join order to make the structural members cutting architectural elements.
ccarniel8
Observer
Observer
Isn't there an "automatic" way to do this? Because I'm working with a not finished structure model in which the civil engineering company is updating us weekly with new ifcs full of revisions. I noticed that if I update the linked model I lose the definitions of the union so it will be a bit of a problem for me...
Either way, thank you for helping 🙂
Okay so they are in a linked model?  It wasn't clear in your initial post.  In such case, you cannot join them to your local elements.  Alternative is to set the link elements cut pattern to something like solid color via VG > link tab > link display > custom > model tab > override them.
