ref plans line cannot be seen in some elevations
Shay.Gaghe
Shay.Gaghe
hi
im using ref plan ,
in some elevation views i can see them all, and in others i can see only some,
what can be the reason?
S
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
Ref plane's line not perpendicular to the elevation view's plane cannot be seen.
Name the Ref. Plane, go to View where you can't see it, Set the Work Plane to the named Ref. Plane/Work Plane, press Show on the Work Plane Panel.  See it now?
