Structural Walls not visible in floor plan
Some of the structural walls are not visible in the Floor Plan View,But Visible in the 3D View.I have given cut plane as 1500 mm.The wall height is floor to Floor.Untitled.png
ennujozlagam
Hello, try check your view template or phasing and see if helps. Thanks
Viveka_CD
Hi @Anonymous
Thanks for posting on the Revit Architecture forum!
Please see this AKN article: Why is the Structural Wall not visible in floor plan?
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
Luiscko
If you want to see your Architecturals Walls and your Structural Walls in the plan view you can change the filter discipline to Coordination.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
Viveka_CD
Hi @Anonymous
Did the recommendations help with your issue? Are you seeking additional information?
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
