structural plan view in revit lt 2019
yuthdanai.s
Observer Observer
Message 1 of 8
yuthdanai.s
Observer
Observer
Anyone please tell me where I can find structural plan view in revit lt 2019?
In full version, it's in view --> plan views. Now, it seems to be missing from that menu.
Thanks!
Replies (7)
Message 2 of 8
LT does not have Structural and Building Systems.
Message 3 of 8
yuthdanai.s
Observer
Observer
Do you mean it doesn't have structural plan view or doesn't have whole structural system? It has menu structural walls, floor slab, columns, beam, etc. though.
Message 4 of 8
Message 5 of 8
moomnamngern
Community Visitor
Community Visitor
Hi - Yued Yuthdanai S. 😊
        Nowadays, Can you do it?.....I don't understand too.
        If it hasn't structural plan view....Will we can draw or present a work perfectly?
        Or you have other methods?......Please share me 🤔
--tao-trairat.....your friend--
Message 6 of 8
RSargeant78
I realize that this question is for Revit LT 2019, so it is a few years old.  But I am using Revit LT 2023 and Can't seem to get a Structural Floor plan.  Even when Using my Template which was created in Standard Revit, and shows levels 1 and 2 to be a Structural Plan - Modeling View in the Properties.  When I go to edit type it says it is in the Structural Plans: System Families category.  If that is the case, one would think that is is somewhere within the models available families, however when I go to add a level it does not provide the option.  so basically I am stuct with 2 level floor plans that are structural plans and all others are just floor plans.  Kind of stinks in my Browser Tree
Message 7 of 8
rhdesignsnm
Community Visitor
Community Visitor
were you able to do a structural framing plan? I want to create simple foundation and framing plans. Is there a work around where you just do it in linework?
Message 8 of 8
RSargeant78
no, unfortunately, I have found no fix for this as of yet.  Everything I have found seems to indicate that I can only create multiple structural levels in the full revit version; LT does not have the option.  It does apparently have the option to use a structural plan view if it was created in the full version though.
