I have placed two structural concrete beams on two different levels.
The first beam has a reference level
The second has also a workplane and an orientation parameter.
How I have done that?
Thank you.
Did you use a sloped plane as work plane??
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
The Orientation only appears when your Structural Framing is on a Work Plane. So the first one of your print screen is not on Plane anymore.
Likely one was placed in the plan view associated with the level and the other wasn't. Same plan view used with both levels one level associated with the view the other not.
Structural framing becomes detached from reference level occasionally also due to large offsets away from refence level etc.
