Structural Framing-Dimension Wood
KirkLB
Message 1 of 8
KirkLB
Presently I am involved with a basement design and understand the placement of exterior and interior doors. What I am trying to do is show just the wood stud walls with no sheet rock or exterior siding attached and the spacing between each stud. Is there a way to use the Dimension Wood found in Structural Framing to create the walls without having to invest in a third party program? Where can I can that helps explain the properties so I can have a vertical stud rather than a horizontal one.
Replies (7)
Message 2 of 8
You can do it quite easily with Curtain Walls, using Mullions for Dimension Lumber and Empty System Panels.
And/or use Beams and Columns.
CW Example:
Message 3 of 8
KirkLB
By using this method I will be able to place windows and doors into it as well?
Message 4 of 8
Sure. Frame the Opening, change the Empty System Panel in the opening to Basic Wall Type and host your Door/Window to the Basic Wall Type Panel.
Message 5 of 8
KirkLB
Thank you for your time and help.
Message 6 of 8
Door in Stud Wall Curtain Wall example:
Message 7 of 8
syman2000
You can check this topic with some sample curtainwall framing.
https://forums.autodesk.com/t5/revit-architecture-forum/extrusion-too-thin-warnings/m-p/9923202#M306...
Message 8 of 8
KirkLB
I do appreciate all the help I can get. This will take some time but with all the responses I believe I can make it happen
