Structural framing and assemblies
CRJFusco
CRJFusco
So I have been learning revit for my company in the precast concrete fabrication. I am using the precast extension to split the walls. Once split I want to make an assembly of the wall and a structural framing angle that will be cast into the concrete. Is there something special I need to get them to join or would I have to make a component family in place of the structural framing?
cbcarch
You could:
-"Nest" the struct. member into the precast panel
-Use a void to cut geometry to "carve out" the precast at the struct. member.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
CRJFusco
That might work for an embedded angle but what about a flush to the face angle?
cbcarch
Same approach--nested struct. family, reference plane with dimension parameter, lock nested family to ref. plane. No void/cut geometry needed.
Cliff B. Collins
