Structural column & concrete Slab attached but line is separating between them
jkp123
Message 1 of 8
jkp123
Hey,
concrete structural column and concrete floor are joined together
both are the same material, and yet i see a line "separating between them".
-tried different section view templates
- there are columns in my project which are fine ( connecting to the slab without this annoying separate line)
asking for your help guys,
thx in advance
Replies (7)
Message 2 of 8
hmunsell
is your section passing thru the column?
Howard Munsell
Message 3 of 8
hmunsell
Howard Munsell
Message 4 of 8
Are you sure you are not seeing the Level Line?
Message 5 of 8
jkp123
yes section pass through column
Message 6 of 8
jkp123
its not a level line ( you can see the level line in the picture above the floor)
Message 7 of 8
MostafaElashmawy
Firstly unjoin them and make sure they are detached then join them again.
Mostafa Elashmawy
Message 8 of 8
jkp123
it worked ...
