Organizing Parameter Naming
2 ANTWORTEN 2
Nachricht 1 von 3
354 Aufrufe, 2 Antworten
Hey there,
I have more than a couple shared/instance parameters in this family. Its an accumulation of multiple nested families and I would like to organize the names of my parameters a certain way when the family appears in project.  Is there a setting for this, or should I just really consider how I name my parameters?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Are you talking about  Parameter Grouping?
Nachricht 3 von 3
BDMackey
In the family you can move the parameters up or down. Select a parameter to move then select the appropriate button at the bottom.
One thing to note, if any of the grouping is collapsed above the current one these buttons will be greyed out.  Also realize that sometimes upon upgrading I have seen these get disorganized.  If you have several parameters I will often use different groups for similar types.  Knowing how these groups apear in the the project will help so here is a link to that organization.
https://bdmackeyconsulting.com/revit-properties-organization/
