- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Working on a job where structural beams will show up as double lines instead of single lines. I've been through several forums and done enough homework so I have already crossed out the most obvious answers.
-I've changed from Fine/Medium to Course in both the View and Visual Graphics
-I've Checked the beam families for a Symbolic line but also I had two Identical beams one showing as double lines and the other showing the single line so I'm sure it wasn't anything to do with the families.
-I've played around with the view range
-I've changed the Discipline
The only way I've managed to fix the problem on the two identical beams was I simply deleted the one showing double lines and copied the single line in its place but now we have a plan showing ALL of the beams as double lines. So any suggestions outside the typical solutions would be great!
Thanks in Advance
