Stringer short at top
waldie.jonathan
Message 1 of 14
waldie.jonathan
I'm trying to figure out why Revit makes the stringers short at the top and how to change it so the stringer meets the header it will be fixed to. See attached for reference.
Anyone know how to change this?
Replies (13)
Message 2 of 14
Edit and Uncheck End with Riser.
Message 3 of 14
waldie.jonathan
Thanks, I have done that before but then the top tread depth is too short... See below.
Am I missing something with how Autodesk has set this up?..
Message 4 of 14
Post your file here.
Message 5 of 14
@waldie.jonathan wrote:
...lengthen the run to align the top tread to the landing surface.
Message 6 of 14
waldie.jonathan
See the attached file. Thanks,
Message 7 of 14
what about this construction?
Using 3 stair types. One for framing (e.g. carriage stringers & treads). One for finish treads/risers. One for the closed stringers.
Message 8 of 14
See attached.
Message 9 of 14
waldie.jonathan
That works, thanks!
I'm guessing you just converted it to a sketch based stair?..
Do you know of any reason Autodesk would have setup the stairs to act like this and require modification?.. I assume there must be some reason for it.
Message 10 of 14
Component Stair (not Sketch) with End with Riser unchecked.
Message 11 of 14
BTW @waldie.jonathan: In case you didn't notice, @ToanDN also fudged the last tread.  Made it 11".  Did you see that?
Message 12 of 14
waldie.jonathan
Ok got ya.
This still doesn't seem to work in the real world because when you have a 1" nosing on the top landing to match the rest of the stair treads, it still only gives you a 9" run on the top step with a nosing-to-nosing measurement. So we are back to the stringer being too short and not reaching the landing when 'end with riser' is checked. The 'end with riser' is needed in order to add the extra 1" back to meet the min. run requirement assuming there is a nosing on the landing.
Message 13 of 14
david3TA7J
Community Visitor
Community Visitor
Did you ever get this figured out? I had the same problem and solved it by selecting the stairs, clicking edit stairs, selecting the carriage, and under Properties-Constraints changing the Upper End Cut to Perpendicular.
Message 14 of 14
david3TA7J
Community Visitor
Community Visitor
You have to do it for each carriage.
