Strikethrough Font in Schedules
julie6V67T
Message 1 of 10
julie6V67T
Hi there,
I am currently in CA and would like to format font in a schedule to be strikethrough text. is that possible?
Julie
Replies (9)
Message 2 of 10
Message 3 of 10
syman2000
I use this website to create the strikethrough.
https://cutekaomoji.com/text-generators/strikethrough/
Copy the text and paste it in Revit
Message 4 of 10
RDAOU
@julie6V67T
I believe it is possible ... even if everyone (including @barthbradley ) tells you it is not
use a font which has a strikethrough (Below GIF...using a multiline text parameter with a custom font)
Message 5 of 10
I never said it wasn't possible.  I said "Vote".
"Impossible" is not in my vocabulary.
Message 6 of 10
julie6V67T
Can you show how to create a text field parameter "strikethrough" on plain text (not associated with a family)?
Message 7 of 10
julie6V67T
THIS FONT CAUSED A FONT MAPPING ISSUE IN MY REVIT MODEL, NOW ALL OF MY TITLEBLOCKS FONTS ARE PRINTING LARGER THAN THEY APPEAR IN THE MODEL. YIKES! THIS METHOD SHOULD NOT BE USED!
Message 8 of 10
julie6V67T
Message 9 of 10
syman2000
I am not having that issue. What version of PDF driver you are using and what Revit version are you using?
Message 10 of 10
I don't have that problem but if you have a font mapping issue when print to  a printer or print to PDF, just embed all fonts in the printer/PDF settings, and uncheck this box.
