If the text style is always added with an arc leader, and it can be changed individually to straight in the Properties Dialog, how to change it so it alway is defaulted to the straight leader?
Thanks in advance.
Solved by EmptySaturnV. Go to Solution.
No default setting unfortunately. I would love if there was, especially for paragraph settings.
instead, it just remembers the last settings used as pointed out in Matthew's image.
