strange wall wrapping behavior
Mohamed_Faramawy
Mohamed_Faramawy
why do this wall wrap behaves differently in both sides red and green i need it to be the same as green.
noting that i made the external finish as a separate wall with wrapping of external for ends and intersections but the green mark is at window but red at door
is the family of windows and door has a responsibility for that ?
koert.vynckier
That usually has something to do with the depth of the voids in the two windows. If you have two identical windows the wrapping behavior will be identical. If your voids are both linked to an element at the same depth, the behavior should be identical.
Mohamed_Faramawy
sorry i didn't understand that, if u please can clarify
Oh, I think I understand what is happening here. Has to do with WALL CLOSURE. Adjust the Wall Closure Ref. Plane in the family (pull it inward a bit - in direction of wall centerline).
Mohamed_Faramawy
correct answer and a great solution from your side. many thanks to u my smart friend
