dwf export grids
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
815 Aufrufe, 3 Antworten
dwf export grids
I have a problem when I export multiple sheets to DWF with a print set in Revit 2016.
If i only export one sheet at a time all looks fine. But when I export a set all the gridlines
from linked files show up.
Anyone had this problem?
3 ANTWORTEN 3
Nachricht 2 von 4
Viveka_CD
als Antwort auf: Anonymous
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Can you share a file to troubleshoot further? I can send you a private folder to upload.
Looking forward to your reply update.
Nachricht 3 von 4
Viveka_CD
als Antwort auf: Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
  • Revit grid components are converted to AutoCAD Architecture grid components. See HERE for more information.
  • Use the tools HERE to create and select views and sheets and for more information on Exporting to DWF see HERE
If you not able to resolve your issue, you can send us a file to troubleshoot. Looking forward to your reply update.
Please mark any posts that help with "Accept as Solution" and thanks!
Nachricht 4 von 4
Hi,i aslo had two problem :
1、When the revit exports DWF, the grid number shift occurs.
2、And my Door and window mark text lose his Aspect ratio of text
I can't find the reason ,it confused me a lot.
I'm so appreciate if you can help me.
vision : revit 2018
My Email: 823394103@qq.com
