I cannot choose the glass part when using storefron wall. I can choose the whole wall and shape handle. I cannot tap through and get to choose the glass, to insert a door.
Solved by alan.johnson7YLND. Go to Solution.
Solved by ToanDN. Go to Solution.
Usually just hover your pointer over the edge of the Mullion and tab through the selectable elements, until the panel highlights. Then select it (unpin), you can then change the glass panel for a door panel from the type selector, if you have a door panel loaded in.
