Storefront door.
Storefront door.
s192019WWFUF
Storefront door.
s192019WWFUF
I cannot choose the glass part when using storefron wall. I can choose the whole wall and shape handle. I cannot tap through and get to choose the glass, to insert a door.
alan.johnson7YLND
Usually just hover your pointer over the edge of the Mullion and tab through the selectable elements, until the panel highlights. Then select it (unpin), you can then change the glass panel for a door panel from the type selector, if you have a door panel loaded in.
alan.johnson7YLND
Can you share your Revit file?
Enable selection of pinned elements, bottom right bar.
alan.johnson7YLND
Yes @ToanDN your right if its pinned and the 'select pinned elements' is off the glass panel will be un selectable.
s192019WWFUF
Thank you!
