Stone path - fantasy
Good evening,
to put this kind of fantasy as stone how can I do?
In the file attached the curve wall is in rough stone.
I create an other wall with finishes in an other kind of stone but the result is the same, only full gray.
Have to work on this properties of material?
.rvt file is attached.
Thank's
Change to Realistic View.
You may be able to find that hatch pattern by searching for "Stone Hatch Patterns" @ Arcat.com
...how about this one? See Attached. You can create a Revit Surface Pattern from this one. Do you know how to do that?
martijn_pater
In case you wanted the hatch pattern in elevations (not the realistic material representation), set surface patterns under graphics when editing material to such a stone hatch pattern (download). You can use foreground for the linework, background to color representation ie. You could create your own model hatch pattern aswell (ie. Pyrevit plugin)
