hello,
i'm having a problem with the section lines, if I create the section in ground floor view , it only shows in this view, it
does not show in 1st or roof plans, why?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von Jason.P. Gehe zur Lösung
open the section and check its view range. the section will only be seen if the sections top and bottom extends are passing thru the level.
Howard Munsell
when I open the section view there is nothing abt view range,
currently it is showing in ground and roof plans but does not show in first floor
sorry... Terminology
by View Range I just meant the top and bottom limits of the sections, not the view range tool for a plan.
basic questions:
Howard Munsell
yes I checked reveal hidden option, nothing is hidden,
I attached an img for the section view
Are the scales the same for all your plans. If they are not, in the section check the properties and make sure your "hide at scales coarser than" is set correctly. Have it set to be larger then the scales of your plans. See attached jpb
