STL CONVERTER ADD-ON
Message 1 of 10
Morning,
I've just reinstalled my Revit onto a new computer and the STL Converter is now missing.
I've downloaded and installed all updates provided by Autodesk but still no STL Conveter.
Can someone please direct me to exact download/hotfix I require?
Much appreciated,
Cheers
Replies (9)
Message 2 of 10
ennujozlagam
which version of revit do you have? you can try this LINK and check autodesk apps store and see if helps. thanks
Message 3 of 10
I have Revit 2020 Student Version.
I had the same version previously and was able to obtain the STL Exporter
Message 4 of 10
ennujozlagam
you can refer to this LINK and see if helps. thanks
Message 5 of 10
Thanks for the link, however it redirects me to the update and downloads which I've already installed.
Is it possible to receive the .exe file from someone so I can install it.
Message 6 of 10
ennujozlagam
you can PM me and give your email add. try to send to you. thanks
Message 7 of 10
Really appreciate it. Sent you a PM. Cheers
Message 8 of 10
ennujozlagam
send to your email add. please check. thanks😉
Message 9 of 10
Unfortunately, the file didn't come through.
Roughly how big is the file?
Cheers
Message 10 of 10
ennujozlagam
check. i reply your PM. thanks
