STAIRS
STAIRS
mishkt
STAIRS
mishkt
I tried to create stairs, but I do not why, I have different heights of risers and one riser just didn't create.
I attached some screenshots of plan, section and 3d view.
Level height - 3240 mm
18 risers
Riser height - 180 mm
Thank you for your help
ennujozlagam
Hello, pick your stair edit then go to properties uncheck end. Thanks
mishkt
Thank you for answer.
Uncheck in type properties?
If yes, it doesn't work
ennujozlagam
Hello, check my stair screencast video and see if can help you. Thanks
@mishkt If doing what @ennujozlagam suggested doesn't work, you may want to edit the stairs and recreate the problematic run.  Feel free to post the Revit file if you want us to look at.
