07:28 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
1_Can anyone help me about how to combine the stairs with upper floor slab.. ( pls check attached file - no:1 ) I couldnt connect the landing concrete with the stair concrete part, stair concrete should be extended and joined to slab. Also same problem in the bottom slab connection ( pls check attached file2 - no:3 )
2_How can we cut the wall plaster in the connection of landing..( pls check attached file - no:2)
Thanks..
