STAIRS PROBLEM
STAIRS PROBLEM
basma_salman
Message 1 of 77
STAIRS PROBLEM
basma_salman
hello,
I am trying to create single step, but it is showing like in img below, it is extending beyond the tread,
I tried to change the connection method, the presentation is not correct
Accepted solutions (3)
Replies (76)
Message 2 of 77
martijn_pater
Not sure I've ever drawn a single step stairs:) I'm thinking maybe I wouldn't use stairs functionality for that actually, and just model it... edit: scratched last remark, using straight cut should work...
Message 3 of 77
basma_salman
it is not just about modeling it, I'm using stair tool so when having a section through it, the details shall be correctly represented
Message 4 of 77
Are you trying to do it with or without a notch?  Without notch should be rectangular.
...Ah, I see what you're talking about. That's the Tread NOSING.
Message 5 of 77
basma_salman
my problem is that the step is extending inside of the wall like in attached images
Message 6 of 77
Do you also have a riser?
Message 7 of 77
basma_salman
I need only 1 riser but my problem is with the part marked in the red circle
Message 8 of 77
That doesn't make any sense me.  Almost looks like the stair is at an angle to the view.  Post the file.
Message 9 of 77
basma_salman
I clouded the part i'm talking abt
Message 10 of 77
This is what I'm seeing in Section. What's not right about it?
This one? Just move the stair forward.
Message 11 of 77
basma_salman
the treads width is not the same, one is 300 and the other is 350
Message 12 of 77
Message 13 of 77
basma_salman
this is not the issue, they are 2 different sizes 😓
Message 14 of 77
basma_salman
the width of the tread should be 300, anyways, thanks a lot
Message 15 of 77
like this?
Message 16 of 77
basma_salman
for the 2 steps yes I want it like that, but for the single step why is it extending to the inside of wall?
Message 17 of 77
I must have sneezed.
Message 18 of 77
Like this?
Message 19 of 77
basma_salman
yes exactly, did use cut profile tool or u actually worked with the stairs settings?
Message 20 of 77
The file is there for you to look at.
