HI
Please Help.
I have a problem with a stair (see attached image). The steps in de middle are cutted, why does this happen?
Kind regards
how did you create the stairs? I've experienced a similar problem when creating stairs by sketch, although the risers look very low so it could be something to do with that?
Hi, yes I needed to do it by sketch. There are two different Radius und a straight part at the end. The risers are 17,5cm and the steps are about 52cm.
I solved it for the moment with three different parts (stairs), but it was a big workaround.
Kind regards
